Orbi WiFi 7 RBE973
Reply
Replacing RBR40 with RBR 750
mark146
I'm replacing an RBR40 with an RBR750. The PW protocol has changed—my RBR40 didn't require caps, while the 750 requires one cap.
I'm changing the network name to avoid making changes on all devices, but the 750's password protocol is defeating that idea. Is there a workaround to that issue, like a way to change the PW protocol?
Message 1 of 6
Accepted Solutions
mark146
Re: Replacing RBR40 with RBR 750
There's probably a 100% chance I'm confused. I'll monkey around with it more over the weekend and reply. Thank you for pointing that out. I'm an idiot when it comes to this stuff.
Message 3 of 6
All Replies
Guru
Are you talking about the log in PW? Log in PW requires a Cap
The WIFI SSID PW doesn't require anything. I use all lower case with mine. Been use same SSID name for years.
Message 2 of 6
mark146
Message 3 of 6
Guru
Any progress on this?
Message 4 of 6
mark146
Yes, thank you, you were correct! I'm sorry I didn't mention this earlier, I appreciate your help!
Message 5 of 6
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1340 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
