Orbi WiFi 7 RBE973
Reply
Satellite Connection
Shenderson0913
The satellite for my RBR40 is not syncing up and not sure what to do.
Message 1 of 4
Guru
Re: Satellite Connection
What FW version is the system currently using?
Same version on both?
Whats the distance between the router and satellite? 30feet should be starting distance.
After the top LED starts to pulsate on and off slowly, press the sync button on the router then on the satellite. Wait about 2-3 minutes and top LED on the satellite should turn on BLUE.
Message 2 of 4
Shenderson0913
Thanks got it working.
Message 3 of 4
Guru
How did you get it working?
Glad you did. Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 678 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
