×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Satellite firmware and constant blue light
Orbibot
My orbi satellite has suddenly kept the constant blue light on, unable to update the firmware, any suggestions?
Message 1 of 7
DarrenM
Sr. NETGEAR Moderator
Re: Satellite firmware and constant blue light
Are you able to log directly into the satellite using its local ip address? and then your can try a manual update of the firmware.
DarrenM
Message 2 of 7
Orbibot
I have tried to do the manual update and it either says failed or service unavailable.
When trying to log in to the satellite it just keeps sending me to the log in page, can’t get beyond it.
Message 3 of 7
DarrenM
Have you tried to factory reset that satellite by holding the reset button for 10+ seconds?
DarrenM
Message 4 of 7
Orbibot
I have reset it, now it keeps going to the magenta color and my router keeps going off and online, the “check for updates” feature won’t complete on the app now. Went back to the orbilogin site and now there are no updates available even the manual way...
Message 5 of 7
DarrenM
What version of the firmware is the router and satellite showing?
DarrenM
Message 6 of 7
Orbibot
V2.0.0.74
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1361 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
