- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellites keep disconnecting after reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
My only workaround has been to reset to factory and reconnect everything from stock.
Anyone else have poor connectivity with the RBS20 Satellites?
latest firmware installed: 2.3.5.36
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellites keep disconnecting after reboot
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 the modem from my ISP is the Arris XB6 (in bridge mode).
my home is 3400 sqft and 3 levels. RBR20 is in the middle of the home on the main floor, one satellite is upstairs in my office and the other is in the basement (centrally). all are about 15-25 ft away. without the satellites, my office only give me a connection rate of 63 Mbps... basement is 24 Mbps.
2.4 GHz channel is set to 11, and the 5 GHz channel is set to 36. there are plenty of others around me on wifi, but my diagnostics scan says the best channels are 11 and 36.
Beamforming, MIMO, and WMM are enabled
Daisy-Chain, Fast Roaming, anf 20/40 coexistence are all disabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, lets try this, turn OFF one of the RBS. Leave the other one on. 15-25 feet is too close. Move the one RBS out to 30 feet.
With just one RBS, can you see if this one RBS will turn BLUE then turn OFF instead of PINK?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, streaming is an issue so I’d like to be able to hardwired first a more consistent connection.
Would playing around with the transmit power and preamble help at all??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible you may have a faulty system out of the box. You may want to return the system and get another or try a RBK50 system if thats available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
probably... our master bedroom is only about 11 feet from the RBR and it wont connect to 5GHz, so im stuck on 2.4GHz 1.4Mbps... only when i have the satellites on (and working!) i get full speeds.
bought this open box from Amazon and they wont replace the unit... also Netgear wont honour the warranty because the original ower had already registered it. SOL for me.
thx @FURRYe38
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya if you can't connect to 5Ghz at that range something is wrong. Hopefully a new system will work better.
@deltaboy wrote:probably... our master bedroom is only about 11 feet from the RBR and it wont connect to 5GHz, so im stuck on 2.4GHz 1.4Mbps... only when i have the satellites on (and working!) i get full speeds.
thx @FURRYe38
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear RBK23
D-Link COVR-3902
Netgear R8000
TP-Link 2600AC
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the building materials of the home? Any old plaster and any lead paint? I have a friend whos house is older 50s style home. Appears to be some lead based paint layers. Wifi signal has had problems with Orbi and some COVR systems. Basement and walls are concrete so this doesn't help either. The COVR 3902 seemed to work best as a trial run.
You may want to try a 50 series Orbi as they have more power. The 20 series I tired in there home didn't work well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
our home was built in 2010, its not old by any means! just so many dead spots that really cripple the network
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the layout of your home?
You might try a 50 series Orbi instead of a 20 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I may just reroute my router to the garage at one corner opposite my family room, so I can add a satellite and hardwire the AppleTV. This configuration will place the main router directly below the office too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure that there is 30 feet in between the RBR and RBS or approximately in that range to begin with.
Try swapping RBS locations to see if the problem follows or not.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
