×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Setting up Wake on LAN on RBR20
heldheld
Hi,
I want to set up Wake on LAN for my PC via my Orbi RBR20 but I can't seem to find the option in the settings of the RBR20. Is it even possible to do this with this router?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
CrimpOn
Guru
Re: Setting up Wake on LAN on RBR20
Alas, Orbi routers are not capable of generating Wake On LAN (WOL) packets.  This is a computer management issue, not a network management issue.  There are numerous alternative tools to generate the WOL packets. Here is one list of tools:
https://www.pcwdld.com/free-wake-on-lan-tools
I love my Orbi.
Message 4 of 5
All Replies
Guru
There's nothing to set in the router. the computer is the one that WOL when something is sent to it.
About the only thing that might help is setting it with an IP reservation
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
heldheld
As far as I understand it, my router (which is my RBR20) has to send the packet to my PC. Every tutorial I've found about the subject states that I have to set that in the settings/web-interface of my router. I can't find that option though.
Message 3 of 5
CrimpOn
Guru
I love my Orbi.
Message 4 of 5
heldheld
Aaaah I see. I found out that the software I downloaded for it has the capability to send the packets itself, I didn't realise that until your post made me look for it. Thanks a lot! Turned out I had everything set up correctly already without even realizing it 🙂
Message 5 of 5
Discussion stats
  • 4 replies
  • 1666 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
