×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Setting up backhaul on an AP orbi
Tempo36
Hey folks,
I have an RBR50 kit (RBK50) set up where the router is set for access point mode and the satellite is remote. We discovered an ethernet port hardwired into the house (go figure!) and so I can potentially set up hardwired ethernet backhaul. Is there anything special I would need to do since the router is in AP mode? Or is it just plug and go. I assume I would have the hardwired connection between the satellite and the orbi router and then the orbi router still is the lone hardwired connection to the centurylink router.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Setting up backhaul on an AP orbi
Should be setup and go.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Be aware of managed switches if one is is use or switches with "Green Ethernet" features. Can cause problems for Orbi with ethernet connected RBS.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
As @FURRYe38 says, plug and go.
I have an Orbi in AP mode on Powerline Ethernet. Nothing special needed.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 5
TaiwanWu
First of all ! Pair the RBR and RBS via wireless !!
this is my setting now
The orbi's AP mode is not what we think AP mode is.
Kind of like Router mode without DHCP.
You need direct connect the existing router with RBR(WAN port), then connect everything under the RBR. What you connect to the existing router can be used, but can't be seen on the Orbi app, thats why the setallite shows disconnected.
Message 4 of 5
Guru
There are no router or routing features working while in AP mode on the RBR. Most it's a switch with wireless radios running.
Any RBS needs to be directly connected to the RBR or thru a switch thats connected to the RBR so the RBS status appears correctly on the RBRs web page and in the Orbi app. Most host routers when RBS are connected to them will not pass thru Orbi traffic between the RBR and RBS correctly which causes the status to not appear for the RBS. So RBS need a direct connection with the RBR or thru a switch that passes all Orbi traffic between them:
Message 5 of 5
Discussion stats
  • 4 replies
  • 1043 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
