× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Sky mesh Orbi mesh incompatibility
jon_curtis
Follower
Hi I have sky mesh system on my sky q box. But can’t get range for another sky mini box as both mesh systems interfere I also have satellite orbi next to sky mini box. Can I connect a ordinary non mesh net gear satellite WiFi booster to my orbi satellite so my sky box can connect via this. Then the mesh systems should not interfere. Ta
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
DatabaseJase
Luminary
Re: Sky mesh Orbi mesh incompatibility
There are a few things to try here. I would change the Orbi 5ghz channel to use a higher channel to move it away from the Sky mesh network. You could also plug the Sky Q mini box into an ethernet port on the Orbi Sattellite if they are so close and not need to use the Sky mesh at all.
We have our main Sky Q box plugged into an Orbi Sattellite via ethernet but the two Sky Q Mini boxes use the Sky Mesh network to connect back to the main Sky Q box.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 767 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
