Orbi WiFi 7 RBE973
Reply
Slow ORBI wired speeds
JugalB
I have the orbi rbk22, the wireless internetspeeds work flawlessly, but when i try to connect my laptop to the orbi via ethernet, the speed is capped at 100mpbs when i look in network and sharing center. My internet plan is 500mbps download which i get connecting to my modem, but i get capped at 100mbps when i connect to the orbi. WHen i checked in prpoerties in network and sharing center, it also says ipv6: no internet access, while ipv4 works. Does anyone know how to fix this?
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 19
ekhalil
Master
Re: Slow ORBI wired speeds
Does your ISP support IPv6? If yes do you have the correct IPv6 in the web GUI under >> ADVANCED >> Advanced Setup >> IPv6 ?
Message 2 of 19
Guru
What FW is currently loaded?
Also try disabling Daisy Chain as well.
Message 3 of 19
ShankarHokie
Apprentice
  1. Who is your ISP? Do they support IPV6?
  2. IPV6 should not matter for speeds. I get the full speed on my desktop via ethernet and IPv4
  3. Have you checked if your network card is capable of 1Gbps? Most old cards are only 10/100
  4. I had similar slow LAN speed and I disabled the daisy chain topology and I got full speed
  5. On the router Advanced => Advanced Setup => IPv6, choose internet connection type as DHCP, IPv6 DNS as automatically get from ISP, and LAN stup as autocnfig
  6. Then test at https://test-ipv6.com/ to see if you get 10/10
Message 4 of 19
JugalB
@ShankarHokie  @ekhalil  My isp is Rogers and yes it does supports ipv6 as well as my network card because ipv6 work and i get the full 500mbps when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop. And how do i disable daisy chain? And another piece of info which could be useful is that i connect the laptop to the main orbi not the satellite.
Message 5 of 19
Guru
@JugalB wrote:
Yes my isp supports ipv6 because i get it when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop.
Message 6 of 19
JugalB
@FURRYe38  where do i get those 2 pieces of information?
Message 7 of 19
Guru
Look at the modem device that the Orbi is connected too. This modem box should have a stick and branding on it.
Unless you connect the Orbi router to a wall out let then, don't worry about finding the Mfr and model.
Message 8 of 19
JugalB
@ShankarHokie when i ran the test-ipv6 it came with a result saying "no ipv6 address detected", but it work when i plug it into my isp modem.
Message 9 of 19
ShankarHokie
Apprentice
Hi.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 10 of 19
ShankarHokie
Apprentice
Message 11 of 19
JugalB
@ShankarHokie i am unable to view you latest 2 responces. Here is what it look like from my end: http://prntscr.com/mg6zhz
Message 12 of 19
ekhalil
Master
@ShankarHokie Please send the pictures as attachements in the post, otherwise they will need a moderator's approval if you post as pictures.
Message 13 of 19
ShankarHokie
Apprentice
Thanks @ekhalil
IPv6 setting attached
Message 14 of 19
ShankarHokie
Apprentice
Daisy chain setting
Message 15 of 19
ekhalil
Master
@JugalB Do you see anything under Router's IPv6 address on WAN below?
Message 16 of 19
JugalB
@ekhalil under Routers ipv6 on WAN it shows 2 up addresses, but under Routers ipv6 address on LAN it says not available.
Message 17 of 19
Guru
Any progress on this?
Message 18 of 19
ekhalil
Master
What LAN IPv6 settings do you have?
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 8215 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
