- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Slow Speeds Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having slower than normal speeds with my Orbi. I have gigabit internet through ATT. I used to have speeds 800-900Mbs wired and 300-400 over Wifi. But now currently having 90-100Mbs over Wifi. With hard reset of Orbi, I have a return of initial speeds but after a couple hours it returns back to 90-100Mbs. I have even installed previous versions of firmware. Only thing that returns my speeds are hard reset of the router.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Slow Speeds Orbi RBR50
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Traffic Meter, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
