×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Slow Wireless - Restart Required
Tbsteph
Star
I have owned the RBR 50 with one satellite for about 3 years. It is connected via  200Mps service from Spectrum iand is n router mode. I have lived through probably 10 firmware updates. Yet, to this day, I need to periodically reboot the system to regain maximum wireless speed. (No problems with ethernet connections.) About every week or so I notice my wireless connetion speed has dropped from around 225 Mbps to 30 Mbps. Why? This situation is annoying to say the least. When the Orbi works it's great. FWIW, I have read many posts on this site discussing slow wireless speed - none of which have which provided an answer. Disable this, enable that, change this, change that - none of which have made a iota's difference. Any thoughts?  Thanks.
Message 1 of 7
Guru
Re: Slow Wireless - Restart Required
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 7
vajim
Master
Any Wifi Neighbors near by? If so, how many?Smiley Happy
Message 3 of 7
Tbsteph
Star
I expected this response. You or someone posts the same thing whenever wireless speed is questioned. Anyway, I have already implemented all of the suggestions made regarding enabling disabling various settings. Firmware is current 2.7.1.60. As mentioned in first post, none of the suggestions make any difference. No interference from neighbors, etc. This is the second home I have set-up with the RBR50 with the exact same problem. The best analogy I can come-up with is the router becomes constipated. Restarting is the only thing that clears the issue. Forgive my venting. I realize this is a user forum and appreciate other users piping in with their experience.
Message 4 of 7
vajim
Master
"the router becomes constipated."
how old is it...Orbi???
and there are lots of complaints about  2.7.1.60.
do a search here....good luck
Message 5 of 7
Guru
Understand the frustrations too.
v2.7 can be a mixed bag of good and not well.
If v2.7 doesn't seem to work well, you might downgrade to v16.
Have you reset the system after any FW update and the problem still continues?
Do you have any Armor, Circle or IPv6 enabled?
Message 6 of 7
vajim
Master
Firmware?
how do you get your current firmware?
Message 7 of 7
Discussion stats
  • 6 replies
  • 478 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
