- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Social Networks not updating
- Mark as New
- Bookmark
- Subscribe
- Permalink
For some time, perhaps after a switch to firmware 2.5.1.16, social networks no longer update or do so once in a while (like every half an hour, or more).
It happens with any mobile phone connected to my WIFI, and with any network (Whatsapp, Telegram, Messenger and Viber).
To have the messages updated, I have to disconnect the phone from the WIFI and connect it to my portable provider.
Even Whatsapp Web on my computer, often doesn't start unless I first disconnect my phone from WIFI.
The internet browsing or streaming work very well.
I also tried to disable the 5G connection and connect the phones to the 2.5G, but the problem stays there.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Glad you got it working.
25feet maybe too close. 30 feet or more is recommended. You may want to turn down the power output of the RBR from 100% to 74 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Mark your thread as solved so others will know.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Social Networks not updating
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed all you suggestions and it seems to work!
The chat applications update now in real time. At least in the last 20 hours.
Bt the way the Orbi is directly connected to the provider (no additional rmodems), it's in an area of less than 300sqft and the satellite is about 25ft far.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
