×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Specify a TFTP server in DHCP settings (RBR50)
bashfulrobot
Tutor
Hi there, I was wondering if there is a way to specify a TFTP server in the DHCP settings on an Orbi RBR50? I cannot seem to find an option. I know at times there are ways to do some limited config over telnet, etc, so I thought I would check in. Thank you in advance. System Info Hardware Version: RBR50 Firmware Version: V2.7.3.22 GUI Language Version: V1.0.0.375 Operation Mode: Router
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
CrimpOn
Guru
Re: Specify a TFTP server in DHCP settings (RBR50)
I am not aware of Orbi DHCP supporting any options.  There is a provision on the WAN setup page to have the Orbi use options 60 and 61 to identify itself to the ISP network, but that's not what you want to do.
The only way to accomplish what you want is to use a different DHCP server on the network that is capable of incorporating options 66/67 or 150.  I have found internet articles talking about using Pi-hole's DHCP this way.  I have not looked at pfSense. (Have Pi-hole. do not have pfSense)
Good Luck
I love my Orbi.
Message 2 of 2
Discussion stats
  • 1 reply
  • 406 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
