Orbi WiFi 7 RBE973
Reply
The LED of the satelites for my RBR40 are always orange
jbc9727
Follower
Hi All,
I just bought my Orbi system last week. I put the main router in the living room and 2 satelites in 2 rooms respectively. Here comes the problem, my flat is like around 800 sq. ft., but both of the satelites are orange all the time. Is there any fix for this?
Thanks
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 2
Guru
Re: The LED of the satelites for my RBR40 are always orange
800sq ft maybe to small of a area for the RBR and two satellites.
Factory reset and setup the RBS 1 at a time. Leave off other RBS. Just work with one RBS.
Message 2 of 2
Discussion stats
  • 1 reply
  • 317 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
