- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to login to orbilogin.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am unable to login to orbilogin.com or 192.168.1.1. I get an error "
Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected:
I have tried resetting to factory setup and setting up the device again. It connects the first time I setup. After that the same error.
Anand
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to login to orbilogin.com
What modem are you running?
you can get errors like that if you've got a double nat going on. (2 routers on the same network both in router mode)
https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using xfinity xfi model. Yes. The problem was the double NAT. The modem had changed the IP of ORBI. So I use that IP address, I am able to login. Is there way to change the default IP of orbi to that? I am using orbi in AP mode, so a lot of options are disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2...
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
