- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unblacklist WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unblacklist WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unblacklist WiFi
I think Spectrum is correct that whatever happens to internet access once it gets past their modem is the customer's business.
This is a little confusing because "EX6150" refers to a WiFi extender that is typically connected to a WiFi system to extend the range.
It can be connected to any brand of router, including Netgear's Orbi.
"Blacklisted" is not a very technical term. There are lots of ways to disrupt internet access. If the brother is in charge of the network, then only he can untangle the problem. On the other hand, if the boyfriend is paying for the Spectrum service, and the brother took advantage of lax security to mess with you, it's pretty easy to sort out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The key is who has access to the main router. i.e. who has access to the main house.
If the ORBI74 is located in the main house, it takes but a minute to stick a paperclip in the tiny "Reset" hole on the back next to the power supply. When the LED next to the power plug turns amber and begins to blink, remove the paperclip. In a minute or so, the Orbi will restart and the WiFi SSID and password will be what is printed on the label.
Family dynamics can be a lot more complicated than technical issues. If this situation is likely to occur again, the only recourse may be to pay Spectrum to install service to the back house separate from the front house.
