Orbi WiFi 7 RBE973
Reply
Understanding my missing download speeds...
Loopy22
Tutor
Hi
I have an RBR20 with 2 sateliites. Latest firmware. The backhaul status is always "5G good".
I have done the following "SpeedTests" downloads ( all very reproducible). I am have a 80Mbps connection to "the internet"
- From AT&T UVerse router  85Mbps
- From ORBI Router - 82Mpbs ( connected to AT&T U-Verse)
- From iMac 27" - 50 Mbps
The iMac is about 6 feet away from one of the satelites and reports a 5G WiFi speed of about 600Mbps, so I would expect I have plenty of "headroom".
So what is happening to my 30Mbps??
Andrew
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 15
Mstrbig
Master
Re: Understanding my missing download speeds...
WIFI speeds are generally less than wired speeds. WiFi is a shared interface while ethernet cable is a dedicated interfacce. so generally wifi speeds are going to be slower. Add to that channel interference. So maybe try another channel, to see if your speeds increase. Enable WMM, beamforming and Mu-Mimo and see if that helps. Disabe daisy chain topology. Uncheck "Enable 20/40 MHz Coexistence".
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 2 of 15
Guru
If you have a modem with a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. Having two wifi sources near by can cause problems as well,
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 first.
@Loopy22 wrote:
Hi
Andrew
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 15
Loopy22
Tutor
I am sorry, but thats not really the answer here. The reason for having an Orbi mesh wi-fi with a 867mbps back haul is so that the wi-fi is NOT the bottleneck. The bandwidth from my Mac to the satellite is running at full 800mbps+ 5G speeds - that is 10x faster than my broadband connection.
Message 4 of 15
Guru
Be ware that 866Mbps is a connection rate only between the orbi wifi radio and the connecting devices. This is NOT a actual speed thru the device.
https://www.lifewire.com/how-fast-is-a-wifi-network-816543
https://www.speedguide.net/faq/what-is-the-actual-real-life-speed-of-wireless-374
https://www.flashrouters.com/blog/2012/11/29/the-difference-between-wireless-n-wireless-ac/
Have you tested a different device besides yoru iMac? Iphone or different PC to compare? Not all devices are the same and will have different performance designs.
Message 5 of 15
Loopy22
Tutor
There is no double NAT going on. The ORBI is in AP mode as per https://kb.netgear.com/26747/How-do-I-set-up-my-NETGEAR-or-Orbi-router-to-work-with-AT-T-U-verse
Message 6 of 15
Loopy22
Tutor
Clearly 867Mpbs ( full 5G ) is unlikely to be achieved. But there should be enough headroom such that if I have a 80Mpbs broadband connection, I should achieve a pretty good percentage of that 80mpbs.
All the fine-tuning of the RBR20 people talk about to get throughput apply with broadband connections of , say, 200-400 Mpbs. My 80mpbs should be easily achievable on every device that is within range of a satelite to get a 5G connection.
Message 7 of 15
Mstrbig
Master
If you are getting 80Mbps on other wireless devices and 30 on your one device, logic would state the fault is with the 1 wireless device. Is it possible that device is connecting at 2.4Ghz? If so and your device supports 5Ghz, forget the Wifi on the device and reconnect.
Message 8 of 15
Guru
I would also try the 1 device connected to the RBR instead of the RBS as well.
Message 9 of 15
Von_B
Tutor
I had the same problem with RBK13.
The cause is agressive QoS (WMM) from Orbi applied to satellite. It always gave me about 65% of my internet speed when using Speedtest, especialy if any other device use the network, even lightly. (short burst low priority data, life FTP Speedtest get lower priority and slow performance)
It's not really a problem though, because in real world traffic, the speed is ok. Try Fast.com for speed test (it's netflix speedtest). Orbi will detect it as high priority traffic (video traffic) and my guess is your Mac will get full 80mbps.
Anyway, speedtest.net is not a reliable way to measure speed on Orbi, that's what I found.
Message 10 of 15
Mstrbig
Master
I find fast.com to be very inaccurate. I found it to be half the speed of several other speed tests including Orbi's built in test.
Testing WMM enabled and disabled on my end resulted in faster speeds enabled, because of ac speed enhancements. Only tested on 5Ghz WIFI.
Message 11 of 15
Von_B
Tutor
Interesting.
Fast.com being slower probably mean it's throttled by your ISP (on my isp it's actually faster than what I pay for 140mbps and i pay for 120mbps.... Netflix server are hosted at my ISP though)
Anyway, me and op have lower tier orbi (RBK13 and 20). Maybe there's difference in how QoS is implemented. We'll see is result.
Message 12 of 15
Guru
I've also found fast.com much different from ooklas installable speedtest app and Orbi built in speed test app. Wired to the RBR is best. Wireless speed testing at the RBS may only provide slower speeds or depending upon wifi hardware and design, speeds may be slower that expected.
Why testing at the RBR wired first is important then testing at the RBR wirelessly is best. Lots of factors in wireless speed testing that produce inaccurate results. Though I would support that the user should be seeing good speeds at the RBR.
Message 13 of 15
Von_B
Tutor
Never mind
Message 14 of 15
Guru
So what that mean? There a change in operation?
@Von_B wrote:
Never mind
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 1941 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
