- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Update Orbi satellite offline through computer?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ive done a factory reset without luck.
There is a new update available and as I understand I need to update the satellite before router.
So, is it possible to update the firmware by connecting the satellite with ethernet cable to computer?
If yes, how do I connect?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minute. The PC will get a IP address from the satellite. it will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Update Orbi satellite offline through computer?
However, did not fix ny issue. Internet still goes offline.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So do you have internet with the RBR if the RBS is not connected?
When the RBS is connected and your connecting thru the RBS, the RBS fails here?
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.zyxel.com/no/no/products_services/Multy-Pro-AC2400-VDSL2-Combo-WAN-Gigabit-IAD-VMG8825-B...
Ive done some testing now..
The RBR is working flawless, but when adding the RBS even the RBR fails as mentioned above. The internet drops out, even though if Im connected to the RBR when checking the app. If I however disable and enable WIFI it gets back online for some time before the same thing happens again.
Ive tried to move the RBS closer but there is no change in behaviour.
Ive tried 30ft, 25ft and 40ft. Plain sight, no walls blocking signal.
Is my RBS dead or whats happening?
Are there any way I can export a log file from Orbi that someone can analyze?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the ISP Modem in router or bridge mode? Should be bridged.
Sounds like if the RBR works alone and then fails with the RBS connected or the RBS fails when connected, something is going on at the RBS.
I would open up a support ticked and ask for help on the RBS. Ask about an RMA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ill open up a RMA, thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
