Orbi WiFi 7 RBE973
Reply
Upgraded from cm700 to cm1200 resulting in speed reduction of device of ahrdwired device on Orbi
Timster
I exchanged my CM700 with a CM1200.
When using the CM700 my PC, conencted through an ORBI would get D/L speeds of 450Mbps.
After swapping the CM, I only get 250Mbps.
However a speed test in the Orbi shows the Orbi is getting 950Mbps.
Is ther a config that changed?
Message 1 of 6
Guru
Re: Upgraded from cm700 to cm1200 resulting in speed reduction of device of ahrdwired device on Orbi
What website are you using for testing? These can be very unreliable if the server the website uses is slow.
Who's your isp?
Have you tried any other devices?
Are you using any traffic monitoring, parental controls, disney circle, access control to manage the orbi?
What firmware is your orbi on?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
Timster
What website are you using for testing? https://www.speedtest.net/ (same as before)
Who's your isp? (Xfinity)
Have you tried any other devices? No, nothing else is ahrdwired
Are you using any traffic monitoring, parental controls, disney circle, access control to manage the orbi? No
What firmware is your orbi on? Latest (just updated)
Message 3 of 6
Guru
https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/td-p...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 4 of 6
Guru
Speedtest.net lets you change servers. Try a couple different ones. I've had the same server show me lower speeds. Switch to a different one.
Have you tried a factory reset? Never a bad idea if the firmware updated and you changed modems.
Message 5 of 6
Guru
I would install Ooklas installable speed test app and compare testing. Sometimes browsers can impact speeds as well. The dedicated speed test app excludes those ads during testing.
Message 6 of 6
Discussion stats
  • 5 replies
  • 980 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
