× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Upgrading from V1.4.0.18
RussFogg
Tutor
Hi, just bought the router and satellite and have V1.4.0.18 FW installed.
They won’t update via the browser connected via WiFi and read on the community I need to manually upgrade to v2.2.1.212 first before trying the latest version.
Tried this but connected via WiFi and not wired and it failed with an incorrect file message.
Support would only say ‘wired is much preferable’
I need to find a wired laptop because I am on a Mac with USB C ports only
So....is my approach right and it is just matter of upgrading manually via the browser via a wired connection to v2.2.1.212?
Thanks in advance...
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 10
Accepted Solutions
RussFogg
Tutor
Re: Upgrading from V1.4.0.18
I am sorted..thanks for the help.
Firefox, turning off the Mac FW and now both units are in the latest FW and what a difference on the interfaces and all is doing well.
Thanks for the assistance- appreciate it.
Message 9 of 10
All Replies
Guru
Review this:
https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1748881/hi...
For Macs with out a LAN port, you can find and connect a USB to LAN adapter that can help add wired LAN support to those PCs.
Message 2 of 10
Guru
Let us know how it went. Hope it was updated well.
Message 3 of 10
RussFogg
Tutor
Thanks will do!
Sorting it tonight - went out and got myself an Ethernet adaptor for the Mac so it is done proper.
Message 4 of 10
Guru
Smiley Wink
Message 5 of 10
RussFogg
Tutor
Okay I need some help pls...
I am connected via ethernet to the RBS50 satellite, I am on FW V1.4.0.18
According to the tips and tricks if on a V1 FW I should be going to RBS50-V2.0.0.74
Downloaded and uploaded that but get a "This firmware file is incorrect!" error.
What am I doing wrong?
Message 6 of 10
RussFogg
Tutor
I have also tried to manually update from a V1.4.0.18.img file becuase read somehwere that could be the issue but that also fails with the same incorrect FW error
Message 7 of 10
Guru
What browser are you using? Safari? Try FireFox.
Be sure you have the right RBS50 FW .img file.
Try a factory reset on the RBS, wait for the connection to be ready, then try to send the img file. I was able to do this on a Windows PC.
Do any of these work?
RBS50 (Orbi Satellite) Firmware Version 1.10.1.2
RBS50 (Orbi Satellite) Firmware Version 1.9.1.12
RBS50 (Orbi Satellite) Firmware Version 1.8.0.6
RBS50 (Orbi Satellite) Firmware Version 1.5.0.12
RBS50 (Orbi Satellite) Firmware Version 1.4.0.34
Message 8 of 10
RussFogg
Tutor
Message 9 of 10
Guru
Awesome. Glad it worked.
Ejoy. Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3481 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
