gp2430
Jan 12, 2021Aspirant
Using Orbi with Xfinity
I have had the Orbi router, and satelite for a few years, and I just switched to Xfinity, and the modem is a combo router.
Will it help my Verizon signal (One Bar), and wifi to still use the Orbi system.
Thanks for any advice.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - CrimpOnGuru - Experienced User
gp2430 wrote:I have had the Orbi router, and satelite for a few years, and I just switched to Xfinity, and the modem is a combo router.
The Orbi WiFi package will almost certainly provide better coverage than the single Xfinity router, so most people would place the Xfinity into "bridge mode" so that all it does is connect the Orbi to the network.
WiFi has no effect on cellular radio signals, so the Verizon signal will not change. Like other mobile networks, Verizon offers "WiFi Calling":
https://www.verizon.com/support/wifi-calling-faqs/ which could enable your mobile phone to operate better while within the Orbi WiFi coverage.
(Although I have Verizon, I have never been able to get it to work. Maybe it's my phone. Maybe my Verizon signal is "good enough". Or, maybe I'm just not smart enough to figure it out.)
- gp2430Aspirant
Thank you very much for the info, and links.
Hope they are helpful.
Let us know how it goes.
