- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using the orbi as a standalone router with fibre optic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Routers and a modems do different things in terms of supplying your internet connection.
There are some devices out there that can do both router and modem functions together in one unit, but they aren't very common (long story).
Orbi is not one of those devices... The Orbi system is a routing device exclusively - it requires a seperate modem to be connected to it in order to produce your wifi network....
Internet cable coming into your house -> Modem -> Orbi -> (wifi) -> your various internet toys
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using the orbi as a standalone router with fibre optic
Hello Charlie97
Orbi is not a modem so you will have to always connect it to a modem in order to get internet access.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not so fast... Most fiber to the home services, including Verizon FiOS, do not require a modem at all, and interface using an RJ45 connection to a router. It's possible the OP does not need a modem. Whether he needs one depends on what Internet provider he uses and what equipment is already installed in his home. If he currently has a box that's only a router, then he might be able to replace it with Orbi.
