- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
V1.3.0.12 - Outstanding Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: V1.3.0.12 - Outstanding Issues
after updating just make sure you re enable the beamforming and mimo on the advanced wireless page as they are disabled by default atm
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I switched the units out. The new unit had older firmware than previous unit. Anyway updated and after a day in the evening when I checked on of the satellite had lost connection or was missing from admin page. I am now thinking it might be the location is causing it to switch or something. But it never happened 1.3 firmware.
The location for this satellite is in the TV closet, it is a closed closet.
Do the satellites have to in the open or something?
Thanks,
Biju
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bijugm wrote:So I switched the units out. The new unit had older firmware than previous unit. Anyway updated and after a day in the evening when I checked on of the satellite had lost connection or was missing from admin page. I am now thinking it might be the location is causing it to switch or something. But it never happened 1.3 firmware.
Thanks,
Biju
Obviously, the more obstructions in the way of any wireless signal, the less signal strength you will have. Depending on the type of construction (i.e. hollow walls/doors vs. solid wood, etc.), it could indeed made a significant difference.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
I moved it to a different location. Hopefully it will stay connected.
Question - do satellites disappear from admin if they can't connect to router and only way to bring them back is to reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes if the orbi sat drops it wont be shown in the attached device list , if the sat is dropping it maybe too far away or having issues with interference
- « Previous
- 1
- 2
- Next »
