× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
VPN issue with RBK752 - connected but no access to internet or local server
xx69
Guide
Hi,
I'm not new to orbi. I've been using a RBK23 since 4 years and it works nicely on my setting.
I'm upgraded with an RBK752 to replace the RBK23 (backhaul speed mainly)
I'm from France and My setting is the folling :
- Orbi in router Mode
- Direct access to Fiber to Ethernet bridge (ONT) - Network Orange (ISP)
- Connection using Orange DHCP (specific ISP setting for France) and my Orange ID
- No IPV6 setting (does not work, don't save the ID in Orange DHCP IPV6 menu - don't care)
- Orbi firmware latest : V4.6.7.5_2.1.7
- Factory reset and clean install (Twice)
- DDNS with netgear. up and running.
- Satelite OK, Wifi OK.
- local IP : 192.168.2.0 (gateway 192.168.2.1)
With the previous Kit I use to connect using VPN acces on both my phone (4G connection) and iPad (away from home).
So I enable VPN chose option 'access for internet and local' and import the 4 files for smartphone on my OpenVPN connect.
Connection is OK on both the Ipad and Iphone. I can see the connection in the Orbi Logs and I've got an address like 192.168.254.2 with a gateway 192.168.254.1.
Seems ok even as it's on another subnet du to the TUN VPN setting.
On my computeur I can traceroute to 192.168.254.2 and get an anwser (routing is working).
BUT on both ipad and iphone I can't access internet site and I can't access local IP like 192.168.2.3 (my NAS). It use to work with RBK23 and not with RBK752. Routing is not working on this side of the VPN.
I've alread factory reset twice and I'm a little bit fed up reseting the thing.
Have you got an idear ?
Little add on, as my RBK752 is form amazon warehouse I can't register it because it's already register (cas open to customer service) and therefor seams to miss some features (like SPC - no trace of it).
Maxime
Message 1 of 3
Accepted Solutions
Guru
Re: VPN issue with RBK752 - connected but no access to internet or local server
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Message 3 of 3
All Replies
xx69
Guide
a add on :
Went trying to connect, errors occurs and DHCP does not work anymore on the RBR750. Disabling the VPN access restore le DHCP.
probably I'm not on the good category
Message 2 of 3
Guru
Thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1204 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
