- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN
- Mark as New
- Bookmark
- Subscribe
- Permalink
VPN
I am in a foreign country and have an Orbi RBK50 mesh. I want to connect dumb devices (i.e. a tv, amazon echo, etc). I would like to connect to a to my friend's VPN using openvpn. I tried to set up VPN service but that did not work. Any ideas? I want to be able to stream and whatnot using that VPN because I can't access some websites or streaming services if the IP is a foreign country. Home Depot is an example of site I can't use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
It usually helps to say a bit more than "did not work".
A good start would be to say you did and where it went wrong?
VPN isn't the easiest thing to configure and depends a lot on the service you are using. It is hard to see where your friend's VPN comes into the picture. Again, too little information for anyone to do more than guess at what is going on at your end.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
If I understand correctly what you are trying to do is have your friend be the VPN server and your Orbi be the client and route all traffic through your friend's network. Orbi supports VPN only as a sever (I.e. when you're not home you can connect to your home network). If I understand correctly keep reading, otherwise ignore 😉
a couple of options could be installing a VPN client on your streaming devices (if you have something like a firetv) or installing Voxel which also has OpenVPN client on the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
Please explain more about Voxel. I do not have fireTV they are android or roku. I have openvpn on the devices that support it but the TV's (as far as I have been able to determine} do not. I also would like Alexa to use the client VPN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
If I understand it correctly, Voxel is alternative firmware that can replace Netgear's official version.
Advice on that is best obtained from the people who write the firmware. Netgear does not support it, and there probably aren't many Voxel users here who can help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
If you want to route ALL your traffic through the VPN tunnel then you should check out Voxel. See http://www.snbforums.com/forums/netgear-ac-wireless.53/, make sure you have the right stock firmware and then flash the latest Voxel firmware. Please remember how doing this at your own risk and you should be comfortable flashjng firmware and if needed restoring the stock firmware with TFTP.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
