× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Voice Sync delays on some websites!
MV007
Follower
Hi All,
I have an RBR50 and RBR50S and ultimately for the last few years it has been working absolutely fine however recently I have been having issues with BBC iPlayer and some websites where there is a half a second or at times a second audio sync delay.
I am not sure what this can be but points to the network as I have checked on extrernal networks and this issue does not exist using the same hardware.
I have also tried my phone and three other laptops in my house on the same network and sadly the same issue with voice sync/delays are apparant.
Any one know what it could be and how to troubleshoot/resolve?
Many Thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: Voice Sync delays on some websites!
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 3
CrimpOn
Guru
Where are you located?
Using a VPN?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 530 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
