Jonesnow
Dec 15, 2021Aspirant
WAN Setup on Orbi RBR50v2
Hi Folks, I need to set up Create a static WAN IP on my ORBI, i.e 192.168.1.1, Gateway 192.168.1.254 and both DNS as 192.168.1.254 The advanced settings has a WAN setup section but that is for a single IP address, where would I be able to set this up on my Orbi? This relates to a solution I have found I need to implement where I have switched my Orbi to the primary router and my ISP's to an AP off the Orbi https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-with-different-Router/m-p/2105648/highlight/true#M77782
Any help massively appreciated!
All of these settings would go in the Orbi web interface, Basic Tab, Internet menu item.
It would help if you could provide some background about the goal of this endeavor. In particular That BT article that was referenced explains how a router (Netduma) was attached to the BT Hub and another device (Asus) attached to the Netduma as an access point. The BT Hub remains in place as the primary router and provides voice service.
Is the BT Hub the ISP device you intend to connect as an access point?
- JonesnowAspirantApologies, aim is to get the Dect phones that can only connect to the BT router working, I will only have two devices in my setup however, Orbi RBR50 and BT smart hub 2, essentially I want the smart hub to be able to connect to the internet through the Orbi rather than the other way around.
My suspicion is that the voice capability is separate from the internet channel and the Orbi will not pass the voice information through to the BT Hub. i.e. no phone service.
And, if the Orbi is connected to the ISP in place of the BT Hub, that business of setting static IP, DNS, etc. is not valid. That only worked in that other post because the BT Hub was left inplace. Whatever device is connected to the ISP will get a public IP address from the ISP and cannot use a private IP address.
I must be missing something, because I fail to see an advantage of connecting the BT Hub to the Orbi in access point mode. (can a BT Hub even be put into AP mode?) Devices will not roam between WiFi signals from the two systems.
