- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What if a mesh wifi access point reaches maximum connections?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What if a mesh wifi access point reaches maximum connections and a new device wants to join the network at the location of that access point? Will the device be switched to the other access point automatically?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What if a mesh wifi access point reaches maximum connections?
I have three satellites and over a hundred devices, so I've been watching closely to see if there is load balancing. There doesn't seem to be. One of my nodes gets over forty connections, while fairly nearby nodes get far less. I believe it is going just on signal strength to determine whether to hand off clients to other nodes, not capacity.
Sean
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many devices do you have connected total?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 I want to have about 50 devices connected to 1 access point. If there's a 51st device wanting to join the network, I will want it to be connected to the other access point in the same mesh network. Is that possible?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very short answer - no. Slightly longer answer - you wouldn't want it to be anyway, because the signal strength (in a proper install) will be much poorer on the other AP.
The number of connected devices is entirely irrelevant (you can literally have thousands of STAs), it's merely a question of *simultaneous and unidirectional* bandwidth utilization.
Odds are, if it _is_ a saturation problem, the backbone is already saturated anyway and it really won't make a whit of difference which AP you connect to, as they will all be equally bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
50 is alot to have connected to 1 AP. It's recommended to have more than 1 AP source and spread the device connections across each AP for best operation and performances.
