× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WiFi Slow after 2-3 days until reboot?
mkfein
Star
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling.
I have 200 Mb/s service from Xfinity. Orbi RBR50 is connected to a CM700 modem. Firmware is 2.3.5.30. Satellite is ~30 ft away from the router. Security is WPA2-PSK [AES] only.
All is great with my wired connections, I always get the full 200 Mb/s.
When things are running well I get consistent 180+ Mb/s WiFi speeds.
About every 2-3 days though, WiFi speeds drop to ~40 Mb/s on all my WiFi devices... even when on 5G right next to the router.
When the slowdown occurs, wired devices remain consistent at ~200 Mb/s.
After a reboot, WiFi speeds instantly return to ~180 Mb/s
I've tried a "hard reset" of the both the satellite and main Orbi.
I've tinkered with the channel settings... I have very little interance from neighbors.
I've tried tinkering with all the advanced options - Daisy Chain, MIMO, Beam forming, 20/40 coexistence, etc.
None of this has worked... like clockwork after 2-3 days it's back to "slow mode" of only 40 Mb/s... and after a reboot jumps right back to 180 Mb/s.
I'm capturing the logs (attached)... nothing looks remarkable?
We have the usual assortment of connected home devices -- 3 apple tv, 1 roku, 2 ring cams, 4 amazon echos, 4 ipads, 2 iphones, imac, 2 pc laptops, wink hub, 2 yamaha AVRs, Rachio, HP printer, 1 google home, sony bluray player, comcast DVR...
I'm out of ideas... and really frustrated with this Orbi system.
Help?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 158
ekhalil
Master
Re: WiFi Slow after 2-3 days until reboot?
1. What 5 GHz channel do you have set in Orbi?
2. Do you see the issue only with devices attached to Satellite or also to the Router?
3. Are you using wired or wireless backhaul (connection between Router and Satellite)?
4. Attached Google Home -and probably Amazon Echos- broadcasts wifi on the same channel as Orbi if Guest mode is enabled in those devices. Can you please disable Guest mode to test. If any of your other devices also does this then please switch it off for testing.
Message 2 of 158
mkfein
Star
Hi,
Thanks for the reply.
1.
2.4 GHz channel is 1
5 GHz channel is 36
Neither channel setting matters, I've tried them all...
2. It happens when attached to the main router, I'm not certain about the connection to the satellite. I can try to test that...
3. Backhaul is wireless.
4. Google Home Guest mode is set to off. The Amazon Echos (dots) don't have a guest mode
Message 3 of 158
ekhalil
Master
Which of your devices are wired?
Will you be able to disconnect all wired devices, reboot Orbi Router and see if you’ll still see the same issue with wireless devices after few days?
Message 4 of 158
mkfein
Star
What would doing that accomplish?
Wired devices are: 1 Apple TV, Comcast DVR, wink hub, Yamaha AVR and a Craftsman garage door controller.
Message 5 of 158
ekhalil
Master
I suspect that one of the wired devices is causing loops in the system which will affect the wireless devices.
Another question: are you sure that the devices are not moving to the 2.4 GHz band which is limiting the throughput on those devices?
Message 6 of 158
mkfein
Star
Yes, the slowdown affects all devices, regardless of the band.
I'm not sure I follow how wired devices could be causing this? What is a "loop in the system"?
I should add, I have a NETGEAR GS308-100PA switch connected to the orbi, and my wired devices are connected to that switch. Speed of my wired devices never slows down, it's always ~200Mbps.
Message 7 of 158
ekhalil
Master
If you're sure that your radio is ok and you don't have interference on the 2.4 and 5 GHz bands from your neighbours then please check your other devices.
Loops are caused by devices which has both Ethernet and wireless interfaces to the router or devices that are faulty or misconfigured. If you have such devices please disconnect them from the network temporarly and see if you see improvemets.
Message 8 of 158
mkfein
Star
ok, thanks for explaining.
I double checked the wired device connections.
  • Unplugged comcast DVR, which doesn't need a network connection... not sure it was even active.
  • Unplugged Sony Bluray player, we don't use the network connection anyway.
  • Apple TV is ethernet only; it is not setup for WiFi
  • Yamaha AVR is ethernet only; it is not setup for WiFi
  • Craftsman Assure Link controlloer is ethernet only
  • Wink Hub is connected with ethernet as primary, and has a "wifi backup". I disabled the WiFi backup option to prevent it from connecting.
Perhaps the Wink Hub is the culprit? I'll know in a day or 2...
Message 9 of 158
mkfein
Star
Like clockwork... 2 days after the last reboot and my WiFi speed is back down to 40 Mbps.
Any other suggestions?
Message 10 of 158
Guru
I would factory reset the RBR and RBS. Walk thru the setup wizard. After the system is setup, I would turn OFF the RBS and switch. Just test the wireless alone on the RBR.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
See if the RBR fails at two days. If it does, I would recommend returning the orbi system or ask NG support for an RMA.
Message 11 of 158
mkfein
Star
Hi, thanks for the reply. I'm past Amazon's return window. How do I get in touch wiht NG support?
I did a hard reset 2 weeks ago, and setup the whole system fresh... which didn't solve the issue. I'd prefer not to do that again, unless there's something specific that I should change?
When the system slowed down last night I double checked the band and link rate of connected devices. Devices that were attached to the hub on 5GHz at a link rate of 800 Mbps maxed out at 40 Mbps. A quick reboot and everything was back to 180+ Mbps. So frustrating.
Message 12 of 158
Guru
Ya sounds like this system needs to be RMAd.
Make contact here:
https://www.netgear.com/mynetgear/registration/login.aspx
File a support ticket.
Message 13 of 158
mkfein
Star
Thanks -- appreciate the help
Message 14 of 158
Guru
Good Luck. Smiley Wink
Message 15 of 158
mkfein
Star
After a week+ trying to register my router, support is telling me the hardware is no longer under warranty... But, offered me "free phone support". So, I guess I'll give that a shot?
In the mean time, I have now realized that the slow down only affects the main router. Devices connected to the satellite maintain speeds of >175 Mbps.
Any other ideas?
Message 16 of 158
Guru
I would make contact with a forum moderator and see what they can do for you:
@Blanca_O
Any other ideas?
Message 17 of 158
ekhalil
Master
What advanced wireless settings do you have?
>>ADVANCED>> Advanced Settings >> Wireless Settings
Can you please try disabling Implicit Beamforming if you currently have it enabled.
Message 18 of 158
mkfein
Star
Implicit Beamforming, MU-MIMO, and fast roaming are all disabled.
How can I get in-touch with a moderator?
Message 19 of 158
Guru
Beamforming should be enabled. Along with WMM. MIMO is only needed if you have any MIMO supporting devices. Fast Roaming is a user option that you can choose to use.
@Blanca_O
Message 20 of 158
ett11
Initiate
I actually have the same issue. Also have RBR50, and the ISP is Spectrum.
I believe is a firmware issue that Netgear has to fix.
Message 21 of 158
spinkick
Apprentice
Its not going to be beamforming or any other feature, unless that feature is causing some sort of memory leak over time. My Orbi system does the same, and I suspect its my multicast devices (Google Chromecasts) that just blast the network with packets constantly. If turning on a feature would fix  your problem, you'd have slowdowns right after factory reset, not 2 weeks after. This implies a memory / resource leak of some kind that needs to be correctly. Orbi tech support will be useless, because they are not capable of changing firmware where the problem lies.
Message 22 of 158
Retired_Member
Not applicable
https://www.netgear.com/search-netgear.aspx?q=2.3.5.30
Message 23 of 158
ekhalil
Master
@spinkick wrote:
.......... and I suspect its my multicast devices (Google Chromecasts) that just blast the network with packets constantly. .....
I also think that the issue buillds up gradually after reboot then this can be cause dby one of more of the attached devices.
The best way to find those "bad" devices is to do an elimination procedure, start by disconnecting all devices and see if you see the same issue then gradually attached the devices to Orbi. This can be a lengthy procedure but I can be the only way to find out those devices.
Message 24 of 158
mkfein
Star
I tried isolating the issue to specific devices without success. I don't even have any google chromecast devices.
I actually managed to get my system to be stable for about a month... then Netgear pushed a new firmware update (V2.3.5.30) and I'm back to having to reboot every 2-3 days. About ready to bag the Orbi and try a competitor.
Message 25 of 158
Top Contributors
Discussion stats
Announcements
Orbi 770 Series
