- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi with No Internet Connection After FW Update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Morning all,
SInce I updated the firmware to 2.5.1.16 from 2.5.1.8, I am having an issue with Wifi being connected but no internet being available. To compound the issue, I get the message of 'Connected No Internet' but still have an internet connection. This happens on both 2.4 and 5 bands.To solve the issue, I disconnect from WiFi and reconnect but this shouldn't be the fix.
As best I can tell, this happens only on WiFi. The laptop I am using to type this up is connected to the network via ethernet and I haven't experienced the issue here.My PS4 is also ethernet connected and while I was gaming last night, the TV kept throwing up 'No Internet Connection' messages dialog boxes but the online gaming was uniterrupted.
I am technically inclined but I readily admit that when it comes to networks and their workings, it completely mystifies me. As far as I am concerned it's witchcraft.
Thank you for any help you can provide. It is greatly appreciated!
Some information on my setup:
ATT/Pace 5268AC Modem
- DMZ+ mode set for the RBR50
- IP address is distinct from RBR50
- Both WiFi bands turned off
Orbi Settings
Internet Connection Status
IP Address 76.XXX.X.XXX - Same as modem
Subnet Mask 255.255.252.0 - Same as modem
Default Gateway 76.xxx.xxx.xxx - Same as modem
DHCP Server 172.xx.xx.xx - Modem's IP Address
DNS Server 8.8.8.8 and 8.8.4.4
Router Information
Hardware Version RBR50
Firmware Version V2.5.1.16
GUI Language Version V1.0.0.375
Operation Mode Router
LAN Port
MAC Address xx:xx:xx:xx:xx:xx
IP Address 192.168.1.1
DHCP Server On
Wireless Settings
2.4GHz Channel - 06
Enable WMM
CTSRTS Threshold 2347
Preamble Mode Automatic
Transmit Power 100%
5GHz Channel - 48
Same Advanced Settings as 2.4
Security - WPA2-PSK (AES)
Enable Daisy Chain Topography - Off - only 1 satellite is attached
Enable Implicit Beamforming - On
Enable MU-MIMO - On
Enable Fast Roaming - On
Internet Setup
No Login Required
Get UP Address from ISP dynamicall - ON
DNS Address - Set to Google DNS servers
MAC AddressUse Default Address
WAN Setup
Everything unchecked except Disable IGMP Proxying
MTU - 1500
NAT Filtering - Secured
LAN Setup
RIP Direction - Both
RIP Version - Disabled
Use Router as DHCP - checked
Advanced Settings
In Router Mode
No Ports Forwarded or Triggered
No Dynamic DNS
No VPN
No Static Routes
No Remote Management
UPnP On - Seems my PS4's IP is listed there in UDP for ports 9308 and 3074
IPv6 - Auto Detect
- Connection Type DHCP
- Get DNS from ISP
- LAN Setup Auto Config
- IPv6 Filtering - Secured
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update as of this moment - installed Firefox (weird it wouldn't work with Chrome!) and was able to roll the firmware back on both the RBR and the RBS to the previous version, which is 2.5.1.8.
Did this around 1600 yesterday afternoon and as of 0930 this morning nothing has dropped the internet connection. Fingers crossed but I feel good that perhaps this did the trick because it would drop multiple times per hour, every hour, for the last couple weeks. Seemed to be the biggest problem on the Samsung S10E and my Androiud HiSense TV (maybe it is a conflict with the Android OS??) and now that I say that out loud, this happened on Android devices. Hmmm....
@BretD Noticed you are an admin on this forum. Perhaps you could pass along my experience with this firmware update to Netgear Support. Thanks!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi with No Internet Connection After FW Update
1 major thing connected device not showing ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try a factory reset and setup from scratch with the RBR and RBS.
Power OFF the ISP Modem for 30 seconds then back on. Walk thru the setup wizard on the RBR.
@dinokath wrote:Morning all,
Orbi Settings
DNS Server 8.8.8.8 and 8.8.4.4Router Information
LAN Port
DHCP Server OnWireless Settings
2.4GHz Channel - 06
Enable WMM
Transmit Power 100%
5GHz Channel - 48
Enable MU-MIMO - On
Internet Setup
No Login Required
WAN Setup
MTU - 1500
LAN Setup
Advanced Settings
In Router Mode
No Dynamic DNS
No VPN
No Static Routes
IPv6 - Auto Detect
- Get DNS from ISP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, should have said that I have done a factory reset
@FURRYe38 wrote:Please try a factory reset and setup from scratch with the RBR and RBS.
Orbi Settings
LAN Port
2.4GHz Channel - 06
Enable WMM
Transmit Power 100%
5GHz Channel - 48
Enable MU-MIMO - On
Internet Setup
No Login Required
WAN Setup
MTU - 1500
LAN Setup
Advanced Settings
In Router Mode
No Dynamic DNS
No VPN
No Static Routes
IPv6 - Auto Detect
- Get DNS from ISP
on both the modem and the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So when walking thru the setup wizard on the RBR with a web browser, does it report any problems getting a connection with the modem?
Did you get up a IP address reservation first for the RBR ON the modem so it's IP address doesn't change and then input this into the modems DMZ+?
Try AP mode on the RBR and disable DMZ+ on the PACE modem. See if the RBR works in AP Mode with the PACE modem. Be sure the modems wifi is fully disabled.
Seem others with various problems with the model modem. Most were resolved by upgrading to the Arris BGW-210 modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, no issues reported when going through the setup, everything connects fine. Yes, the IP address is reserved on the modem's DMZ and doesn't change.
If I do the AP on the RBR, don't I lose the Netgear Armor and the firewall on the Orbi?
If the problem is with the modem, why did it work just fine before the FW update? Tried to roll back the FW update and can do it on the satellite but the router keeps locking up the GUI and resetting the interface.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the web page on the RBR reports no internet connection after the setup completes?
You don't need Armor or firewall in AP Mode as firewall is handled by the main host router up stream.
What browser are you using to downgrade? Use IE11x32 or firefox.
You are using a wired PC to downgrade? Don't use a wireless connection for FW dowgrades.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBR reports internet works fine. It's the WiFi connected devices that report 'Connected but No Internet'. It is intermittent and seems to be isolated to the WIRELESS devices. The WIRED devices that are directly connected to the RBR via ethernet are working just fine.
I get that the firewall on the 5268 works but I paid for Armor and like the interface and protection it affords and would rather it work as intended.
Using Chrome 83.0.4103.97. I'll download IE and Firefox and try as you suggest and report back.
Yes, using a PC directly wired into RBR to attempt the downgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
The firewall the ISP modem needs to be disabled since the RBR is in router mode. Having two firewalls running is not good. Be sur the wifi radios on the modem are fully turned OFF.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:It's been running for 2 years just fine. But, it's around 30 feet, yes. What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
All this is in the post above. Again, it was working great up until recently.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? Yes, I live in a neighborhood and can see 3 - 4 other networks when looking. I have been diligent to make sure our channels do not overlap.Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Tried that several times and in every variation over the last two weeks. Still cannot get it stable.,
Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Yep, been there, done this.
The firewall the ISP modem needs to be disabled since the RBR is in router mode. Having two firewalls running is not good. Be sur the wifi radios on the modem are fully turned OFF. Yes, firewall is disabled due to the DMZ+ setting and yes, the radios are off on the 5268
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try AP mode with the DMZ disabled on the modem.
One last thing would be to factory reset and not enable Armor to see if Armor maybe causing problems. Armor has been known to cause some problems.
Contact NG support for additional help and information as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the effort. I appreciate it. This thing is driving me crazy...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Understand man. Orbi can be probmatic for sure.
As last restore, You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
You can revert back to stock FW if it doesn't work out for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having exactly the same issues. Tends to drop on WiFi about 11pm each night for almost passed week. We as only when I jumped on an IPAD there was a notification on ORBI app that my firmware updated to 2.5.1.16, six days ago which is about right.
I think this update has caused my issues. It's been great to date and should be for money I paid for the kit.
I've not yet tried a factory reset but sounds like didn't help you?
John
Orbi Settings
LAN Port
2.4GHz Channel - 06
Enable WMM
Transmit Power 100%
5GHz Channel - 48
Enable MU-MIMO - On
Internet Setup
No Login Required
WAN Setup
MTU - 1500
LAN Setup
Advanced Settings
In Router Mode
No Dynamic DNS
No VPN
No Static Routes
IPv6 - Auto Detect
- Get DNS from ISP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is Armor or Circle enabled on your system?
Please try a reset on yours....
@JaGresh74 wrote:Having exactly the same issues. Tends to drop on WiFi about 11pm each night for almost passed week. We as only when I jumped on an IPAD there was a notification on ORBI app that my firmware updated to 2.5.1.16, six days ago which is about right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I avoid chrome for doing any FW updates.
Wonder why some users are having difficulty with this version of FW, even after a reset and others are not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update - The rollback of the firmware continues to provide stability and has solved the problem I was encountering. Unless something changes, I will not report back. Thanks again for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad reverting back helped.
Next time, try manually loading FW by downloading the FW files and applying them manually. Factory reset and setup from scratch. Next time.
Please mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just another follow up. Still no issues since rolling back the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
