× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Wifi Speed Issues on Orbi AC3000
Sanketh
Hi All,
I recently bought Orbi AC3000 Tri Band for my house. I previously had google wifi but moved over to Orbi as friends suggested higher throughout. I have a 1gb comcast line- With ethernet cable, I get upto 950 MPBS (on Arris sb8200) but with Orbi, I only get 450 MBPS tops. Can someone guide here?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 14
Guru
Re: Wifi Speed Issues on Orbi AC3000
Are you testing with a ethernet connected PC with the Orbi. Don't use wireless. Wireless speeds on client side hw varies and some device don't support 900+- speeds. You'll need to check with the devices Mfr to see what actual thruput speeds they support. Most mobile devices don't support much over 400-500Mb.
What FW are you using on the Orbi?
Message 2 of 14
Sanketh
Hello- I am tested with Ethernet cable connect to Dell PC. Sorry- I am a rookie in terms of terminology- Can you please tell me what MFR stands for?
My Setup: Arris sb8200)>Orbi AC3000>Mac book pro or iOS.
Please let me know if there is a trouble shooting steps I can follow
Message 3 of 14
Guru
Mfr=Manufacturer
Does the Mac have ethernet support? if it does, try testing with that. Most wifi on Mac or mobile devices won't see those higher speeds.
Message 4 of 14
Sanketh
Hello-
My mac does not have an ethernet port unfortunately. Is there anyway I can change the band width to 5ghz only?  Also, thank you for the clear explanation about IOS.
Message 5 of 14
Guru
Does the Mac Book show being connected on 2.4 or 5Ghz. I believe if you hold down on the Option key on the keyboard then select the wifi icon on the top tool bar, this will show you which freqency your connected too.
Orbi is set up to autmatically connect devices to the best frequency automatically. Orbi doesn't allow for using of separate SSIDs between the radios. This would effect how the mesh system works.
Message 6 of 14
Sanketh
I will definitely try this when I get home. Thank you once again for the help.
Message 7 of 14
Guru
Smiley Wink
Message 8 of 14
guzzijason
Apprentice
The best you can realisticly hope to achieve over WiFI with the Orbi is in the ballpark of 500-600 Mbps, and that will vary depending on how "clean" your WiFi environment is. It also assumed there are no upstream bottlenecks.
Message 9 of 14
Guru
Also depends on client HW support as well.
Message 10 of 14
Sanketh
Is that because of Orbi Limitations or something to do with the Modem?
Message 11 of 14
Guru
Limitations of the client wifi HW.
Message 12 of 14
guzzijason
Apprentice
For reference:
https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
These are theoretical limits based on the Orbi radio configuration. Your actual speeds will be less than this, whis is perfectly normal.
Message 13 of 14
Guru
Good Info. Thanks for posting.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3644 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
