- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Will Not Factory Reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of a sudden today my Orbi router stopped working. After searching it looks like a firmware was inadvertantly released? Well now I can't reset the main router. Sticking a pin in the reset button for 20+ seconds does nothing. Also just unplugging and plugging it back in does nothing. I don't know what else to do.
Purchased this back in Nov 2017. Can someone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Will Not Factory Reset
Can you access the UI, you can do a factory reset in the routers web page. "Erase" Found under Advanced/Advanced Settings/Backup.
What FW version is loaded on the router?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can I access the UI if I can't connect to its wifi? Hard connection? Right now it doesn't even look like its booting up. The green light on the back is green but not even the LED's blink if I try turn it on/off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connect ethernet wired PC to the back of the router and see if you can log into 192.168.1.1.
Check the PCs networking settings to see if it's getting an IP address from the router.
Are you sure your feeling the back button push in? Should be a quick bump when you push it in then bump when you let go.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately its not getting an IP. Doesn't even feel like its powered on even though the green light is on on the back. Like I said, prior, I would unplug the power and plug it back in and the LED ring would flash. Now it won't even do that.
So I'm probably SOL?
Right now had to plug in an older router (R6300V2) to use for the meantime. This router doesn't give me full coverage in my home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay...i don't know how but I got the LED to start flashing white. What should I do now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will the PC get an IP address now? It should.
See if your mobile app sees the routers wifi at all...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even when I got the LED to flash white, it was not broadcasting its wifi and hooking it up to my pc via cable was not providing an IP address. At that point I pulled the plug and plugged it back in and again the LED was no longer flashing again however the green light was on. Attempting to reset it with the PIN (holding it in for 20+ seconds) did nothing.
Anything else I can try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your not getting any wifi SSIDs or IP addresses on ethernet with a PC, I recommend you get in contact with NG support. Something has happended to your router and needs to be reviewed. Ask for a RMA if needed.
Let us know how it goes.
@RegDawgwrote:Even when I got the LED to flash white, it was not broadcasting its wifi and hooking it up to my pc via cable was not providing an IP address. At that point I pulled the plug and plugged it back in and again the LED was no longer flashing again however the green light was on. Attempting to reset it with the PIN (holding it in for 20+ seconds) did nothing.
