- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired to Wireless data loss
- Mark as New
- Bookmark
- Subscribe
- Permalink
Setup RBR50/Orbi AC300 + three RBS50 Satellites. Firmware: V2.7.2.102.
We've just recently switched to Google Fiber with an average up/down of 950 Mbps wired. The average wireless speed throughout the house is 300 Mbps.
This seems like a massive loss between wired and wireless. Are there any settings on the router I can change to improve on the wireless speeds? I believe all settings are currently default.
Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wired to Wireless data loss
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
You'll not see anything near 900Mpbs on 5Ghz AC. Most devices max out at around 400-500Mbps depending upon there design and support. WIred speeds you should see near 900Mpbs. Orbi is cabable of that on the wire only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much! I'll try these and let you know how it goes. Appreciate it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
