Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Yes another RBR50V2 dropping connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-06-08
03:41 PM
2021-06-08
03:41 PM
I have a RBR50V2 with firmware V2.7.2.104 connected to Optimum internet Arris Modem Touchstone CM8200. Warranty swapped my router with NETGEAR & warranty swapped the modem with the ISP. Tried the telnet fix as described in other posts but when I enter the commands for root my windows 10 does not recognize the command root. Any one know what I might be doing wrong at the telnet prompt? Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-06-08
03:49 PM
2021-06-08
03:49 PM
Re: Yes another RBR50V2 dropping connection
You mean this?
Be sure your running a telnet session wtih Admin rights enabled?
Check your telnet app mfr for help and support for there app.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-06-09
08:37 AM
2021-06-09
08:37 AM
Thank you. I enabled telnet in the router debug login and setup telnet on my windows 10 laptop as admin but none of those commands work in telnet. Am I missing something? Thank you again
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-06-09
09:27 AM
2021-06-09
09:27 AM
What telnet app are you using?
Putty or Terra term?
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-06-09
09:44 AM
2021-06-09
09:44 AM
I’m using the cmd prompt inside of windows 10
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-06-09
09:51 AM
2021-06-09
09:51 AM
Try Terra Term or Putty and see.
Message 6 of 6
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
