Orbi WiFi 7 RBE973
Reply
can not telnet RBS40
valleynomad
I have RBS40 converted from RBR40. It runs on V2.5.1.16. which has the option of enbaling telnet access. However, whenever I try to login as admin it keeps asking for correct login credential as if I gave the wrong id and password. I don't have issue with web access as admin. Did I do something wrong? Or is it just impossible to telnet access Orbi satellite?
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: can not telnet RBS40
You can try the user name "root".
This is sort of uncharted territory.  We read comments from users who say they have changed a router into a satellite, but I have never interacted directly with someone who has actually done it. (I certainly have not.) Probably the best move would be to search for specific users who did  this hack and ask them.
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
valleynomad
"root" works! Thanks!
Then I tried admin and found it somehow worked as well. But the session was ended unexpectely after several minutes.
telnet my RBS40 using root as id is stable.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 911 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
