- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cannot connect to internet when ups is active orbi20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ,
I have the orbi20 with 2 sattelites .
The orbi is connected to a modem with cable .
the modem and orbi router connected to UPS .
When there is a power outage the modem and orbi getting power from UPS
the modem works good and I can connect to it's wifi and surf while no electricity
the orbi get power but I see blinking white and I connect and disconnect from it and cannot surf the internet .
It seems that it has some issues because the sattelits not getting power but still I need to be able to connect to the router and surf.
Any Ideas ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cannot connect to internet when ups is active orbi20
What is the Mfr and model# of the ISP modem the NG router is connected too? Buit in router here by chance?
I would not include the RBS in with any emergency batter backup configurations as this would draw more power from the UPS or a UPS. The only item you need if you want to provide some wifi internet access while the UPS is engaged during a power outage is the ISP modem and the base RBR only.
Possible the UPS may not be delievering enough power when it's engaged. To test this out a bit more connect the ISP modem and RBR to a power strip thats connected to a wall out let. Then simulate a power outage by turning off the power strip for 30sec to a 1minute. Then power it On. Check the RBRs top ring LED behavior. Does it pulsate or flash WHITE or does it turn BLUE then turn OFF. OFF means the RBR is working normally.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
What are the results for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to be clear, neither of the satellites are connected to UPS, and you do not expect them to function during a power outage, correct?
If the modem and Orbi router are both connected to (the same?) UPS, when power goes out both the modem and Orbi should continue to function normally. That is how my modem/Orbi are set up and that is what they do. (I also have a desktop on the same UPS, and it also continues to work normally.)
The Orbi router pulsing white indicates "factory default mode". When the power comes back on, does the Orbi function normally?
p.s. You mention the "modem WiFi", which indicates that the modem is actually a modem/router/WiFi device. There are distince disadvantages to running two routers and two WiFi networks. But, that should be a separate issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
v2.3.5.26
technicolor TG789vac v2
it's a modem router
This is exactly how it is , only the modem and orbi base connected to the UPS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes . exactly
On regualr basis i'm not using and disabling the wifi of the modem .
I had a situation when the poer outage was not long and the orbi router + the sattelites return to normal ,
and when I it was long one of the sattelites become red and I I got connected disconnectd from the orbi base till I restart the sattelite by unplugin the electric cable .
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is the ISP modem working in? Modem only mode or Router mode?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Possible the UPS may not be delievering enough power when it's engaged. To test this out a bit more connect the ISP modem and RBR to a power strip thats connected to a wall out let. Then simulate a power outage by turning off the power strip for 30sec to a 1minute. Then power it On. Check the RBRs top ring LED behavior. Does it pulsate or flash WHITE or does it turn BLUE then turn OFF. OFF means the RBR is working normally. What is the result of doing this simulated power bump test?
@zvikagutkin wrote:What Firmware is currently loaded?
v2.3.5.26
it's a modem router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is that a power strip connected to the UPS? IF so, this needs to be removed. Its recommended to not use any power strips behind a UPS. Both modem and RBR needs to be connected directly to the UPS back plug ins.
Try a different UPS to see if same thing happens?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@zvikagutkin wrote:Here is a video that show the issue
Thanks for the video. Actually, it looks like two power strips. What was unplugged? (white power supply) Was that the Orbi power, or ....?
p.s. Glad to see that other people have the same nest of wires under their computer desk as I do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry for the late reply , I needed to sort soemurgent stuff .
Anyway thanks for the info .
I don't have another UPS to test .
I don't think that because it plug to power stripe cause this issue as I unplug it from this power stripe and then it needs to work the same as the modem works . I did switch the UPS to connect direct to the power supply but it was the same .
I also tried to disconnect the sattelits and then do the power outage but same issue .
I tried to connect only the ORBI to the UPS (move the modem to the main power ) but same issue .
I upload another video that shows what's hapenning .
Isn't there any logs that I can search what's going on ?
This is frustrating as I thought the Orbi will give me better expirenece than the nighthwak I had but it's not .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Welcome back. The new video may not have uploaded?
I was interested in which device was being unplugged in the previous video. In my (limited) experience, UPS tends to have a "regular electrical plug", but it looked like a transformer plug was being removed from the plug strip. It looked a lot like the Orbi power supply. Of course, that cannot be the case because that would make the Orbi power off completely - dead, no lights, nothing.
I have a UPS powering my modem, Orbi, and desktop computer. When the mains power goes out, all three remain in service as long as the cable company is providing service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the UPS i bought
it's suppose to be for computers with monitors that's why I needed a converter for regular plugs .
I didn't find any other UPS (or better, mini UPS ) for 220V that I know working with Orbi and I can buy it .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting the video. It appears that the UPS does not switch to battery quickly enough for the Orbi. i.e., the Orbi detected that power was interrupted (power LED went out), power came back and Orbi reboots (power LED Amber), then the power LED turned Green and the Orbi router was in "Factory Default Mode" (flashing). Orbi color codes are here:https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
It could be:
- There is something wrong with the Orbi. That it should have "kept going" while the UPS switched from mains to battery. Maybe a bad capacitor in the power supply or something. (The modem seems to handle the UPS switchover.) The way to test this would be to swap in another Orbi, which is impractical.
- The UPS does not switch quickly enough, but the modem is built to handle a longer outage than the Orbi.
I think the Orbi needs to be on a different UPS. Rather than one that "switches to batter", perhaps one that is constantly on battery so there is no switchover. (I remember reading about there being two basic types of UPS: Standby and Line Interactive. Here's a good explanation: https://download.schneider-electric.com/files?p_Doc_Ref=SPD_SADE-5TNM3Y_EN
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 things
Sometimes when I there is a power outage or even when I make a change in orbi configuration one of the satteliits goes red and I need to restart it for the entire mesh to work. I thought that even if one sattelite loosen connection or some things happen to it they otherwise willingness work without it. What I'm experiencing is that there device is connect to the router and then loose the connection and again loose connection... Till I rebooting them bad sattelite.
This makes we wonder if if it's badge hardware.
Second
Where can I find such ups that works with orbi an use 220v?
- Mark as New
- Bookmark
- Subscribe
- Permalink
When the power goes out and the Orbi is in that strange "pulsing" condition, satellites will be unable to connect. If the power comes back on, the satellite will boot up and not be able to connect to the router until you deliberately power cycle it.
My modem/Orbi/switch/desktop are connected to an APC Back-UPS NS 1350G (that I purchased at a discount place, either Costco or Sams Club). It is a line interactive type.
Geez. I have absolutely no information about 220v UPS, and cannot even imagine what sort of plugs you need. A suggestion: since no one else has posted on this topic, you might create a new post with a title like "Please Recommend UPS for Orbi in <country> (220v, type X plugs)". I know there are people who follow the community forum and live in the UK, Europe, New Zealand, South America, etc. Surely one of them will be more competent on this suject than I am.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks a lot .
I will create a new post but just wants to understand if I have an hardware issue .
What do you think ? last time I changed configuration (Disabled WMM ) and when applied I started to get connected/dicsonnected loop . I reliazed that one of the sattleits has an issue and I went to see it, it was red and I needed to reboot in order to solve it .
So I'm trying also to understand if I have a bigger problem that UPS 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree. The video was pretty persuasive to me. The UPS lost power, and instantly the Orbi power LED went out, then turned amber which indicates starting, and then green. I think it happened so fast that the Orbi got confused. So, yes, it could be a faulty component inside the Orbi.
