Orbi WiFi 7 RBE973
Reply
losing ISP connection - after V2.5.1.16 update
Tchalk
My Obri system lost its connection to the ISP for no apparent reason (Comcast didn't have an outage) two days in row around the same time of day in the afternoon. Both times I have rebooted and it starting working again. This issued started after updating firmware to the most recent V2.5.1.16. Is this an issue for others? Other than this recent issue, my setup has been working great for a year or two now.
Possibly related, the distance between my satellites and router are pretty far. I am back hauuling an ethernet connection to a natural switch. Should I be enabling the " Enable Daisy-Chain Topology?" I'm wondering if I had it enabled before and after update it got unselected and it causing a crash of sorts?
Thank you everybody,
Tyler
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Guru
Re: losing ISP connection - after V2.5.1.16 update
I
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
What is the distance between the router and satellite(s)?
Message 2 of 6
Tchalk
Thank you, Furry,
I just enabled the Beamforming and MIMO and it's now working. My outdoor office is about 40 feet from the house with a trenched ethernet cable going to the satellite back to the switch. Other than mesh wifi not working well with RING security and Yale locks, the system works great. Here's a pic of my setup... that I'm unable to upload?
Message 3 of 6
Guru
Glad it's working better then.
Message 4 of 6
Tchalk
Thanks Furry, but... right on que yesterday afternoon (about the hottest time of day) it shut down again while both my wife and I were working from home. Again the restart fixed it. I've enabled daisy chain settings now (to see if that helps) and also just just noticing in my log reports that I'm getting a lot of Dos and ARP attacks. Maybe it's related to that too?
Are there any security setting you'd recommend short of using a VPN, worried that setting up VPN will create issues with logging into work networks?
Message 5 of 6
Guru
You may want to check with your ISP.
Does this happen everytime at same or near same time in the day? if so, this maybe ISP related...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 790 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
