Orbi WiFi 7 RBE973
Reply
maximum length of wired ethernet for orbi ac3000
kelsoken
Follower
Want to connect Orbi Ac3000 router to (1) satellite and was wanting to know:
maximum length of wired ethernet for orbi ac3000 to satellite?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
dpdurst
Luminary
Re: maximum length of wired ethernet for orbi ac3000
I would imagine the standard 90m or 328feet
Message 2 of 3
DavidShawP
Star
Standard Cat5 has a maximum segment length of 100m.
https://en.wikipedia.org/wiki/Category_5_cable#Maximum_cable_segment_length
The maximum length for a cable segment is 100 m per TIA/EIA 568-5-A. If longer runs are required, the use of active hardware such as a repeater or switch is necessary. The specifications for 10BASE-T networking specify a 100-meter length between active devices.This allows for 90 meters of solid-core permanent wiring, two connectors and two stranded patch cables of 5 meters, one at each end.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 984 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
