Lalomie's avatar
Lalomie
Follower
Aug 10, 2022
netgear orbi router RBR50v2
I purchased a device that requires 2.4 GHz router. How can I connect it to my router?
ME.
  • CrimpOn's avatar
    CrimpOn
    This may be the most common question on the forum.  99% of the time, this statement about 2.4G WiFi is similar to the statement "requires 2 AA batteries.  If you have NO 2.4G WiFi network, (none, zero) then the device cannot connect because it has only a 2.4G WiFi radio chip.  (If you have only C cells and D cell, that gizmo that requires 2 AA cells cannot work.)
    Just go ahead and set it up.  Any time a warning appear, just click on "Continue"
    If there is a problem, please report what the device is and someone on the forum will probably have suggestions on how to proceed.
    • michaelkenward's avatar
      michaelkenward
      Lalomie
      You can also home in on possible solutions by searching this forum for the device that you are trying to connect.
      Most of the widely used Internet of Things (IoT) "toys" have appeared here at some time or another.
