- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
orbi 6
hello, i purchased 2 x orbi packs and 2 seperate orbis so i could have a total of 6 units
withb only using 1 router
the 2 units woth the pack connect ok and the 2 extra units connect ok but it transpires the 2 units in the other pack are tied down to their router
how do we default / reset the two units so they will connect to a different router
i have tried all the usual factory defaults and nothing seems to work
many thanks
scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi 6
What model Orbi are you referring to? RBK50 series or RBK 7 or 8 series?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi 6
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi 6
@sjm1967 wrote:how do we default / reset the two units so they will connect to a different router
It sounds like the Factory Reset was not done completely.
https://www.youtube.com/watch?v=cMw4ePACgc4
Either the WPS method or the web mamagement "Add an Orbi Satellite" method should work
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
