Orbi WiFi 7 RBE973
Reply
orbi RSR10 with wired router
jkb24212
I have an Orbi 10 (RBR10) mesh router and one satellite. I am using the ISP provided modem that contains a wireless router BUT the wireless part of the router is disabled. I have wired devices like NAS connected to the router ports as well that I need to access wirelessly. The Orbi internet port is connected to the wired router and works great. Since the NAS is wired to the router on a different IP gateway from the Orbi, and has a DNS server, not sure I should set all wired connections with a fixed IP address then turn off the DNS in the router to avoid having the ORBI and router DNS conflict. I would like to WIRELESS access to the NAS
Advice please
Message 1 of 4
Accepted Solutions
Guru
Re: orbi RSR10 with wired router
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 4
All Replies
Guru
Couple of options,
Message 2 of 4
jkb24212
Thanks very much. I think this is the info I needed. Im on my own I think with the ISP. They aren’t interested in any config outside of their “plug and play” scenario. I disabled the wireless part of the router in the modem before setting up the Orbi and will keep it that way. I may have to operate the Orbi as AP mode since I cannot access the cable router even using a direct connection, odd as this appears.
The cable router had its gateway/DNS set to 192.168.1.1 but during the troubleshooting , I reset it to default which is apparently the same DNS gateway of the Orbi. No matter what I try, I cannot establish a connection the the cable router. I even disconnected the Orbi , restarted the PC and the cable router, no joy. I only have one older netbook that has an Ethernet port, the other laptops are WiFi only. Turning on the WiFi in the cable router requires the ISP to do this because they charge $5/mo extra if you enable wireless. Capitalistic greed for every cent! So, even though I’m limited to one combination not the others. I do appreciate your offering that solution.
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 882 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
