× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
orbi and U-verse how to keep firmware updated
angularone
ok guys I used RonV42 instructions to hook up orbi a guest SSID. all is working well. my question is on the lines of how do keep the firmware updated on the orbi?
Message 1 of 5
antinode
Guru
Re: orbi and U-verse how to keep firmware updated
> [...] how do keep the firmware updated on the orbi?
   I know nothing, but there is a whole Orbi forum:
      https://community.netgear.com/t5/Orbi/bd-p/Orbi
Also, an Orbi "support" page with a "Firmware and Software Downloads"
link (which is where I'd probably start):
      https://www.netgear.com/support/product/orbi.aspx
Message 2 of 5
DarrenM
Sr. NETGEAR Moderator
Hello angularone
The firmware is updated automatically.
DarrenM
Message 3 of 5
angularone
I understand that in orbi mode. But since I set it up under the att U-verse as an Ssdi guest it does not show under orbi app. So how does one keep firmware updated?
Message 4 of 5
st_shaw
Master
As said already, the Orbi updates firmware automatically, with no user input required.  This, of course, requires Orbi to be on a network with Internet access.  I have no idea what an "Ssdi guest" is, but If you have Orbi  on a closed network with no Internet access, which is unlikely, then you will need to manually update the firmware by downloading the ffirmware from Netgear onto a PC, logging into Orbi with a web browser, and uploading the file from your PC.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2535 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
