× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
orbi rbk50 help
bigmoe80
Guide
orbi rbk50 help
just got the Orbi rbk50 to try it out to see how it performs so my issue that it doesn't connect to satellite unless it close by
so not sure why it has to be close i thought this was a system to use all over home my other router NETGEAR RAX50 so im trying both
of these systems out to see how they perform so im surprise the range on the rax50 is suppressing the rbk50 at the moment so any info or help thanks
Message 1 of 15
CrimpOn
Guru
Re: orbi rbk50 help
By default, Orbi satellites connect to the router using a 5G WiFi signal. 5G has greater bandwidth than 2.4G and (typically) there are fewer 5G WiFi devices competing for the same bandwidth.  However, 5G does not penetrate building materials as well as 2.4G.
As the Netgear guide points out, when the satellite displays a BLUE ring light for two minutes (and then turns off), the signal is "Good".  Amber means "Not Good Enough" and Magenta (sort of red) means no communication at all.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
As a general rule of thumb, most users attempt to place the satellite approximately 30 ft. from the router and observe the ring light.  If it turns BLUE, then maybe a bit farther away will work.  Not BLUE, it needs to be closer.  It all depends on the building dimensions and construction. In my case, 30 ft. would be in the middle of the living room.  Nothing to place the satellite on and no electrical outlet to power it with.  I wound up at about 25 ft. and it works great.
Is 30 ft. close by?
Message 2 of 15
bigmoe80
Guide
Re: orbi rbk50 help
ok thanks for advice i went throudh the setup twice and flashed white and then stop i guess it was trying to sync
Message 3 of 15
bigmoe80
Guide
Re: orbi rbk50 help
and my house is a one level house
Message 4 of 15
CrimpOn
Guru
Re: orbi rbk50 help
My practice with satellites is to first pair them in the same room as the router. That way, I can use the router web interface on my PC, handle the sync buttons on the two units, and watch the ring LED without running all over the house.  Once the satellite is successfully paired, it can then be moved anywhere in the house, plugged in, and the ring LED observed.
Orbi satellites will also connect to the router using Ethernet cable (no longer than 300ft.)
If the satellite does not pair when sitting in the same room as the satellite, it may take a Factory Reset to clear out any existing configuration on the satellite (not the router).
Message 5 of 15
bigmoe80
Guide
Re: orbi rbk50 help
ok im give that a try in the same room and see how it goes again and reply afterwards give  me a few minutes if you would
Message 6 of 15
bigmoe80
Guide
Re: orbi rbk50 help
ok for some od reason it wasn't connected at first so i just happen to log in orbi and it disappeared and then pop up and saying
satellite connected im not sure what happen i didn't change any settings
Message 7 of 15
CrimpOn
Guru
Re: orbi rbk50 help
Now you can experiment with different locations.
Like many people, I signed up for internet through my cable company (about 20 years ago? I forget.) and had the cable drop placed in my "computer room" in one corner of the house.  Fast forward through 15 years to people carrying tablets, smartphones, laptops around and the complaints started, "Why is the internet so slow in the LIving Room?" and other places.  My WiFi router in the original location was beaming nearly 75% of the WiFi signal through the walls to outside.  After considering LOTS of options, I replaced it with Orbi RBK50 and put the satellite where it would broadcast "in a circle" that covered those spots the primary location missed.
If I had it all to do over again, I probably should have moved the cable location to the center of the house.  Oh, well. Live and learn.
Message 8 of 15
bigmoe80
Guide
Re: orbi rbk50 help
well i really didn't have no dead zone my last router went out on me so i was trying to figure which or if i need to upgrade so
was look at the orbi system vs wifi router6's so i have both of these at the moment so i have 30 days to try them both and
see which one will suit me
also what setting you have your orbi on mine is still on default
Message 9 of 15
CrimpOn
Guru
Re: orbi rbk50 help
The only 'settings' that I changed from default are:
  • Defining CloudFlare and Google DNS in place of the DNS servers provided by my ISP.
  • Reserving IP addresses for most of the devices on the network.  (I like to know which IP belongs to which device. Not sure entirely why.)
  • Defining user friendly names for every device.
  • Setting up OpenVPN (mostly because it's there and seemed interesting).
If coverage is not really an issue, there is not really much need for a mesh system.  The entire purpose for a mesh is to blanket the entire building with one WiFi network where devices can roam seamlessly from one part of the building to another.
The RBK50 came out in 2016, when WiFi6 (802.11ax) was still "coming soon" and WiFi6E (6GHz bands) was not even on the horizon.
If devices capable of WiFi6 (or even 6E) are likely to be in your future soon, those capabilities in a single router might be important.
Also, the Orbi is not designed for gaming.  People who fixate on latency often complain about Orbi and the inability to prioritize certain devices or activities.
Message 10 of 15
bigmoe80
Guide
Re: orbi rbk50 help
okay yeah i purchased the orbi to see what difference it would be vs rax5400 so really not a difference i got 30 days
to try out and return so im see how it goes
yeah coverage is really not my issue i just want some that give me a constant wifi connection for my wifi device such as my wifi security cams my firesticks
oh so the orbi wouldn't be good for ps4 online gameplay yes or no
well im not sure if in the future if i will have wifi 6 devices what are some wifi 6 devices
is the rbk5 wif5 or 6
Message 11 of 15
bigmoe80
Guide
Re: orbi rbk50 help
so meant to ask you what if you enable these options and how neccasry or if needed are they
beamforming
mu-mimo
the rax50 has
beamforming plus
mu-mimo
ofmda
Message 12 of 15
CrimpOn
Guru
Re: orbi rbk50 help
RBK50 is WiFi5.
I do not play internet games, so have no personal experience. Will be keeping my RBK50 for some time, as there is only one device in the house that supports WiFi6 (iPhone) and it is almost never taken out of a purse.
Message 13 of 15
bigmoe80
Guide
Re: orbi rbk50 help
oh ok so the orbi would be still good for future
Message 14 of 15
KevinLiT
NETGEAR Moderator
Re: orbi rbk50 help
Hello bigmoe80,
Welcome to the NETGEAR Community!
WiFi5 is feasible for most use cases. However, the need for wireless internet depends on the user. If you are going to add Wi-Fi 6 or AX systems to your network it would be best to upgrade to WiFi6. If most of your devices use WiFi5 then you would not be able to get the desired WiFi6 speeds on those devices.
Let me know if you have any additional questions!
Best,
Kevin
Community Team
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2226 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
