- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rbk20 SUDDENTLY failed to USE 1000MBS, instead it stays on 100mbs only
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought this orbi rbk20 with 7 months ago, used to be able to support my 1gb pc network, but since a week ago, i dont know why it it stayed on 100mbs on all of my pc incluuding desktop and laptop. however when i use the speedtest inside 192.168.1.1 the setup page, it can exceed 100mbs and reach 1000mbs, firmware is v2.5.16, nothing being turned on (without any QoS or anyother speical setting turned off). it isnt about my broswer coz i test with different browser, plz help, thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rbk20 SUDDENTLY failed to USE 1000MBS, instead it stays on 100mbs only
have you tried a different cable?
if you log into your cable statistics page, what does it show? (in the browser, log in and click on advanced------>show statistics in the internet port box)
- Mark as New
- Bookmark
- Subscribe
- Permalink
more info,
1 wifi is fine, can go very fast speed
2 same cable, havent upgraded anything including cables
3 if bypass the orbi, connect directly to the modem, works also fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
@HAKW02 wrote:more info,
1 wifi is fine, can go very fast speed---faster than the 100mbps?
2 same cable, havent upgraded anything including cables----again, try checking the cables, they've had issues before.
3 if bypass the orbi, connect directly to the modem, works also fine---"works fine" what speeds do you get? works fine doesn't tell us much.
i attached the statistics that I'd asked for so you can see what we're looking for.
- Mark as New
- Bookmark
- Subscribe
- Permalink
oh, i unpluged and repluged the lan cable to the orib and it suddenly worked, thx for helping anyway thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd keep on eye on that cable. maybe a pin/wire in the cable is bad. or corroded.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
