× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
rbr40- router offline
joecard
my router is offline unable to connect to the modem.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 5
Guru
Re: rbr40- router offline
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Power OFF the ISP modem and RBR for 30 seconds, then power ON the modem and let it sync, then power ON  the RBR. Does it come back online?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Message 2 of 5
joecard
I did that process but it still not working. The ring light remained solid magenta
Message 3 of 5
joecard
Nokia intertek 4006119
Message 4 of 5
Guru
This modem or ONT have a built in router by chance?
Try this, Power OFF the modem for 30 seconds then back on. While this is happening, press the reset button in back of the Orbi RBR for 15 seconds then release. Use a wired PC and web browser and walk thru the setup wizard at 192.168.1.1. This should help you get the RBR connected.
Be sure to use a good quality LAN cable. Swap out. CAT6 is recommended.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1028 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
