× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
satellite not sinking
Paulk2078
I have installed the system however the satellite will not connect despite being next to it, any ideas please. I have rebooted the system and disconnected etc.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 12
vajim
Master
Re: satellite not sinking
how far is the sat from the router?
rim color?
Message 2 of 12
Paulk2078
They satellites go white pulsing then one goes purple, the other doesn’t do anything g and they are within 1mtr of the router
Message 3 of 12
vajim
Master
Guru
What Firmware version is currently loaded on the RBR and RBS? THis a new RBS being added? If so, FW maybe out of sync with the RBR. The RBS may need to be manually updated to same version as RBR.
Message 5 of 12
Paulk2078
How would I make sure they are all on the same system if I can’t get them to sink.
Thanks
Message 6 of 12
Guru
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR
Message 7 of 12
Paulk2078
Will the router need to be connected to the internet or just powered up ?
Thank you
Message 8 of 12
Guru
Just powered up. IF you already have FW files, on a local wired PC, the RBR and RBS don't need to fully connected to the internet.
Message 9 of 12
Paulk2078
Sorry what are FW files
Message 10 of 12
Guru
Firmware files that need to be downloaded from NG download site and unpacked and then applied using the RBS web page:
https://www.netgear.com/support/
Type in the model # if our system and proceed from there.
Message 11 of 12
vajim
Master
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1156 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
