Orbi WiFi 7 RBE973
Reply
wifi
joejohn007
Follower
wifi
when I try to connect to wifi I get 404-not
Model: RBK43| Orbi AC2200 WiFi System
Message 1 of 2
Guru
Re: wifi
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What devices are you trying to connect to the wifi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 514 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
