Feb 09, 2025Guru - Experienced User
Re: Orbi 772 slowing ALL my devices to less than 200mbps
1.I know you said you're on the latest firmware, but what actual version do you have?
2. what modem/gateway is it connected to?
3. you won't hit faster than 200mbps over 2.4ghz. I'm impressed if you're actually getting that. the 5ghz yes.
4. Might try reinstalling the firmware (in case its corrupt), factory resetting (I know you already did), and then reinstalling fresh and not from a backup (in case something in settings is corrupt).
5. Try testing the speeds without the satellites connected.
6. Is ipv6 enabled?
7. what app/speedtest are you using and whats hosting it?
8. what hardwired speeds do you get?
Hi plemans!
First of all thanks for your reply!
I am glad to share that I figured out what happened, but will first answer your questions.
- V10.5.13.1_2.2.34
- It is connected to an Askey modem (I’m in Brazil)
- Actually I was at 6ghz, my mistake.4. Might try reinstalling the firmware (in case its corrupt), factory resetting (I know you already did), and then reinstalling fresh and not from a backup (in case something in settings is corrupt).
- Tried, didn’t worked out
- Same results
6. Is ipv6 enabled?
- BINGO! Will better explain below!
- Netflix “fast.com”
- Same 200mbps
As it turns out and long story short, my problem was related to IPv6!
I was really convinced that it was related to Double NAT, because when I put the modem in bridge mode it solves all issues. However, leave it in bridge mode is not an option as it disables my cable decoders. I called my ISP/cable provider and made them replace the modem, and I even changed some advanced configurations to try to have the internet in bridge and keep the tv working, but I have lost all interactive options for the TV.
Then I decided to turn on my 963 and check all options in every single menu, and I found out that Netgear started to ship the new devices with IPv6 on by default and on pass through mode. This was making the Orbi device correctly assign the IPv4 address, but acquiring the IPv6 address from the modem as its router. When I’ve turned off the IPv6 all started to work flawless like magic.
My final message to Netgear in this case is to better disable it again on next firmware update by default, and if someone needs IPv6 they can enable it by themselves.
Thank you for the ideas and support, plemans!
Another thing you can try if you're leaving your gateway as a router is the orbi in access point mode. it disables some functions but leaves the gateway managing all the router functions and the orbi just acting as an access point. That'd help with the double nat too.
- I thought on it too, but the features I’d lose would make remote management impossible.
Now with IPv6 disabled it is working perfect!
Time to talk with Netgear about the app issues but the most important is the performance being solved!
Thanks for your assistance my friend!
