guptaus's avatar
guptaus
Follower
Sep 03, 2022
AT&T Fiber and Orbi RKB753
Hi All,
I upgraded to AT&T Fiber Optics about a year back. I was using Google mesh router Gen 2. After struggling for a few months, I upgraded to from 600mbps to 1 GB.  Not great so, upgraded to Orbi RKB753S with two satellites in December, 2021.  It worked fine for a while, and then the past few months, the WiFi has been disconnecting randomly and re-starting after a minute or so.
Had the AT&T tech come out. She said that the Orbi router was too close to the AT&T modem. So, I moved the router downstairs, hardwired.  It still disconnected last evening.  Called AT&T and they said that no dropouts on their end.  They think it is a compatibility issue and recommended replacing the Orbi router with AT&T wireless extenders. Reading the reviews of AT&T wireless extenders, this sounds stupid.  I am at my wits end and could use some advice.
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2...
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
  • guptaus wrote:
    ......She said that the Orbi router was too close to the AT&T modem. .....
    Does that mean that he AT&T modem have wifi? If yes, then it's a router! Ether get help from AT&T to change it to bridge mode or change the Orbi to AP mode (if it's now in ROuter mode).
