Orbi WiFi 7 RBE973
Reply
AX-4200 / 6000 MetroNet compatibility
PSSnyder
Orbi ax4200 compatibility with MetroNet
I am considering getting an ac4200 Orbi wifi 6 router to use with my MetroNet 500g fiber, but was concerned about MetroNet’s use of CNAT instead of true WiFi 6 addressing. Does anyone have positive or negative experience with MetroNet and Netgear WiFi 6 Orbi routers? Thanks
Message 1 of 6
CrimpOn
Guru
Re: AX-4200 / 6000 MetroNet compatibility
Most of the people who participate in this forum own the original Orbi products.  Netgear created a separate community forum for the new "AX" product line.  (Google searches for "orbi forum" lead here, whereas the AX forum is at:https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax )  If you post in that forum, maybe one of those folks has MetroNet fiber.
Message 2 of 6
CrimpOn
Guru
There may be a "typo" in the original post.  I believe the topic might be IPv6 addressing, not WiFi6 addressing:
https://en.wikipedia.org/wiki/Carrier-grade_NAT
Message 3 of 6
Guru
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-an...
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Message 4 of 6
PSSnyder
Sorry- my notification for replies did not work, just saw the replies. The ONT is a Nokia G-010G-A, part of their 7368 ISAM system.
Message 5 of 6
Guru
Orbi systens should work with your ISP services.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1243 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
