Orbi WiFi 7 RBE973
Reply
Access my router settings though the default gateway or though the app
SilkyS
Guide
I can also not access my router settings though the default gateway or though the app.  Has this been fixed?  I have RBR750
Message 1 of 9
SilkyS
Guide
Re: Access my router settings though the default gateway or though the app
Hold on I just saw the blurb at the top.  Your telling me they want me to factory reset?  Give me a break get you firmware updates right before you push them out
Message 2 of 9
CrimpOn
Guru
Customers who are desperate to have access and cannot wait another minute have the option to factory reset and reconfigure the router.
Customers who elect to wait will probably have a solution pushed in the next few days.
Some customers have volunteered to have test versions of the repaired firmware pushed to them overnight.  Most are reporting success.
Message 3 of 9
SilkyS
Guide
It's been a week
Message 4 of 9
CrimpOn
Guru
more than a week since that god-awful firmware was pushed out and caused the problem.
only a couple of days since Netgear had new firmware to push overnight.
I can think of many descriptions for this episode, none of which are suitable for "general audiences"
Message 5 of 9
SilkyS
Guide
hopefully it is an easier fix than the Oculus firmware that required me to root the headset to change the time so it would connect to the internet.
Message 6 of 9
SilkyS
Guide
Still no access to my router settings
Message 7 of 9
SilkyS
Guide
I decided to pull the plug on the router to manually reboot it (since I couldn't do it thought the settings).  Finally have access again.  If anyone is still waiting for access try rebooting.
Message 8 of 9
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 842 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
